Ana içeriğe geç
• Giriş jakları: iPod™ dock konnektör / 3,5 mm stereo jak • Hoparlörler: 2x Ridge TM tiz/orta ses sürücüsü ve 2x Atlas TM bas sürücüsü • Amplifikatör gücü: 2x15 Watt tiz/orta ses, 2x30 Watt bas • Frekans aralığı: 40Hz – 20kHz • Giriş empedansı: >10kOhm • Güç kaynağı: 8x D pil/batarya, güç adaptörü • Boyutlar (UxGxY): 500 mm x 230 mm x 240 mm
Standard vs. Rechargeable batteries
Hello,
My Harman Kardon go play 2 takes 8 D cell batteries. Each being 1.5 volts, that makes 12 volts of power. Rechargeable batteries operate at 1.2 volts giving me 9.6 volts. I've read that some electronics are sensitive to voltage changes like this and will fry while others are not. Is it safe to use rechargeable batteries in the Go play 2?
Thank you
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Tyler media,
Well, I guess you can try, I think is a good investment.
For me, I do buy many rechargeable batteries, somehow for alkaline batteries, if left out for long time, the probability of leaking is high and the leaked chemical can damage terminals and seep into the circuit board, damaging it further.
You need to get a battery charger.
Some say Nitecore D4 is great, which I had one too
And perhaps AA to D cell converter / adapter
I had several batteries, ranging from Panasonic / Sanyo Eneloop and recently using Ikea Ladda battery.
I think if your side has ikea, you can consider it.
For this appliance I will recommend you to go for Eneloop pro series from Panasonic or Ikea Ladda 2450.
Link
https://www.panasonic.com/global/consume...
https://www.ikea.com/us/en/catalog/produ...
Interesting Reead
https://petapixel.com/2018/02/16/eneloop...
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
وواتننتن ادااا اهخخ ههههت تتتت تتت
Puan 0
Yorum Ekle
Yanıtını ekle
Tyler media sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 1,674
