Ana içeriğe geç
Third generation Surface Pro tablet, released June 20, 2014.
Having touch issues after installing a new lcd digitizer
Im currently the owner of a computer repair company that fixes many devices but the surface still seems to give me issues my personal surface pro 3 as well after replacing the lcd digitizer on this unit i continue to have touch problem mainly a dead spot in the top left corner about and inch from each side i have replaced the part thinking it was defective but it is not the odd part is if the lcd digitizer is lifted out of the body it works fine not until i lay it in place does the touch issues arise and suggestions would be helpful thank you
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Check the original screen and compare to the replacement screen. There are usually spots that are covered with tape those spots are covered usually to avoid contact with metal surfaces.
If the replacement screen does not have those spots cover use kapton tape (yellow tape) to seal those spots and hopefully it fixes the problem.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Jonathan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 191
