Ana içeriğe geç
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
Car won't stay running.
Brand new fuel pump. Only starts with starting fluid. Idles then shuts off. Press throttle immediately stalls. Service engine light on.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Sounds like it’s not getting enough fuel. Could be a blocked fuel filter, EGR valve, mass airflow sensor, bad coil. Could be lots of things. Try pulling any stored codes via a diagnostics tool. Any codes should shed some light.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
The mass airflow sensor located at or near the induction box. Try disconnecting it and start it. It should run and stay running, but will run rough. If this happens it maybe a mass air flow sensor.
Puan 0
Yorum Ekle
Yanıtını ekle
Razors Nation sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,239
