How can I fix my sliding door motor?
The door motor won't turn off after the door closes.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
There is/was a recall out on that model with regards to the sliding doors. Do check about this with your local dealer. Here is more info on it.
Of course I am not sure which model year you have, but thought I let you know.
Here is what the service manual says about your door system.
The Power Sliding Door (PSD) system is activated through the use of the following: Remote Keyless Entry (RKE), overhead console switches, B pillar switches or the DRBIIIt. These inputs are hardwired to the body control module (BCM) and can be monitored with a diagnostic tool. The BCM will send the message via PCI bus to the power sliding door module (PSDM). The sliding door must be in the full open or full closed position to operate.Once the BCM sends a button activation message to the PSDM, the module shall read all inputs, outputs and vehicle conditions to determine whether it shall open, close or inhibit the PSD operation. During an opening or closing cycle, the PSDM can detect an obstacle present should it meet sufficient resistance by the hall effect sensors (integrated inthe drive motor).
During an open cycle, multiple door activations (RKE, overhead console, B pillar) are ignored until the door reaches the full open position. However, during a close cycle, a 2nd door activation (RKE,overhead console, B pillar) will reverse the door to the full open position. If the engine is cranked during a power open/close the PSD will pause then resume after engine cranking.
In addition, if the vehicle is placed in gear during an open cycle, the PSD shall reverse direction and begin closing. If the vehicle is placed in gear during a closing cycle, the PSD shall continue
closing until fully closed. If the inside or outside handle is activated during an open or close cycle, the PSD will become a full manual sliding door. When the child lockout switch is “on” or “enabled”, the B pillar switches are inhibited from opening a fully closed power sliding door. However, the B pillar switches are allowed to close a fully opened power sliding door. There is only one part number for the power sliding door module (PSDM). The driver sliding door harness has an additional ground circuit which will identify it as the driver side. This eliminates the need for a left and a right side module.
The PSDM can be flashed on vehicle via PCI bus with a DRBIIIt diagnostic tool. The DRBIIIt can read all inputs, actuate all outputs, read module information, and read diagnostic trouble codes. As a reminder, some DTC’s can be set during normal PSD operation.
Sounds pretty intense :-) I guess what I would do, is to get it diagnosed. Either by a local dealer or you could try Autozone and see if their free diagnostics could pick this up. It could be anything from the Sliding Door Modules to a Hall sensor as well as one of the few switches that controls each door. I attached the block diagram for the R door (not sure which one you are having trouble with ) and posted the electric module part of the service manual right here. I do hope that this will help you out. Good Luck
Bu yanıt yardımcı oldu mu?
can you post the electric module part of the service manual again, i cant download it from the link that you gave.
thanks
Where is the positive & negative terminals on the motor?
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 20,180
