Ana içeriğe geç
Support for gas-powered and electric golf carts, sometimes referred to as golf cars or club cars after the Club Car Golf Cart brand.
494 Soru Tümünü görüntüle
Ez go rxv won’t turn on and won’t read charger, no head lights turn on
We replaced the battery that died and also bought ad tested a brand new charger. All are fine. Batteries hooked up correctly. The cart won’t turn on, the battery charger doesn’t show it’s charging and the head lights don’t come on. Any ideas
Bu iyi bir soru mu?
Puan 1
2 Yorum
I upgraded the controller installed
RXV FRDM 48v
Mode: 1206AC-5213. The solenoid clicks but when you want to take off and you hit the gas pedal it won't do anything it won't run?
tarafından
Any idea what more we could check
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
the_leonards  you did not tell us if you checked the batteries with a tester to see if they do have to proper voltage If they do but your cart shows no sign of life you can try and test the power going to the motor controller. Check for blown fuses on your cable to the solenoid etc. EZ Go has a real fancy diagnostics tool so you can also consider having it scanned. I’d check on the solenoid an the motor controller to see if you get power to that. Also, do not forget to check your key switch.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
the_leonards sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 31
Son 30 gün: 164
Her zaman: 8,695
