Ana içeriğe geç
This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
218 Soru Tümünü görüntüle
Screen messed up after isopropyl alcohol. Fixable?
So after I cleaned the board with isopropyl alcohol after some water damage but I cleaned some metal parts off the screen because there was some corrosion. After I did that the phone now starts up but the screen now looks like this now. Is this fixable or is it permanently going to be like this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
You have moisture in between the diffuser layers of the backlight. You're probably looking at a screen replacement or at least if you have the tools and skills a backlight replacement. It looks like a replacement screen assembly is only about $30 with the frame so that probably your best option as long as your confident the phone will work still after the water damage repair.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
jimmysofat6864 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 191
