Ana içeriğe geç
The Honda Fit, also marketed as the Honda Jazz, is a five-door, front-engine, front-wheel drive B-segment subcompact car manufactured and marketed by Honda since 2001 and now in its third generation. Marketed worldwide and manufactured at ten plants in eight countries, sales reached almost 5 million by mid-2013.
20 Soru Tümünü görüntüle
Location of ECT Sensor 1 on top of motor
I can not find the ect location on top or side of motor. Already change ect 2 on radiator just need to figure out where #1 is located
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@mgd1216 ECT 1 is under the air cleaner assembly. You need to remove the air cleaner to get to it.
Bu yanıt yardımcı oldu mu?
Puan 4
4 Yorum:
can you sell me where the crankshaft sensor is? i see its on the diagram but is it front back or rear of the engine ?
tarafından
@robertjohn11533 it is on the front of the engine
tarafından
how do you remove the air cleaner to get to ECT 1
tarafından
You need to unscrew the two screws holding the filter housing. Unscrew the clamp between the top of the housing and the throttle and remove the clamp that also connects another accessory to the filter housing.
In Polish:
Trzeba odkręcić dwie śruby trzymające obudowę filtra. Odkręcić obejmę pomiędzy górą obudowy, a przepustnicą oraz zdjąć obejmę zaciskową która również łączy inne akcesorium z obudową filtra.
tarafından
Yorum Ekle
Yanıtını ekle
Mitchell Dye sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 54
Son 30 gün: 217
Her zaman: 10,226
