Ana içeriğe geç
Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
20 Soru Tümünü görüntüle
Are these parts necessary?
Hello, I am repairing my good old OPO, because of a broken display. I bought a new one with edge, because mine is completely broken. But there are parts in my old case, which aren’t in the new one (see in the pictures at the bottom the missing grid-foil, the missing black foil and the black foil in the place of the motherboard).
New case:
Old case:
Both (old one in the button, the new one above):
Are these foils necessary?
Edit:
Sorry if haven't point it out, but don't think of the stick tape. I made a new photo to show which parts i meant:
But thanks for this really fast response!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The transparent blue are tape covers!
You carefully pull them off to expose the top side of the double stick tape surface to hold your ribbon cables going to the main logic board and the bottom tape holds the lower board in place.
The 3M logo’ed part is also a tape which holds your battery after you’ve put the back cover back on.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
[image|1775511]
tarafından
Yorum Ekle
Always carefully peel off anything u can that is missing on any phone or any device theres usually a reason for all of it…
Foil is usually to act like a heatsink/heat shield
Tape is usually to insulate or stop components touching other parts
Rubber gaskets and seals are for protection or covering speakers and microphones to eliminate other noise etc and around light sensors to stop light leaking in
P.s dont forget to transplant that earpiece speaker too and at the bottom of the pic there are I think 3 little things sticking out of holes I dont know what they are but stick them in too
Puan 0
Yorum Ekle
Don’t worry about them.
Puan 0
Yorum Ekle
Yanıtını ekle
Moritz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 81
