Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Soru Tümünü görüntüle
Soru Kapandı
Screen won't turn on but iTunes recognizes the phone
Originally phone was dropped and landed on the power button which is now hard to press. But did a tear down and checked all the connections. After reassembly, when plugged in iTunes recognizes the phone, but the display is completely black. Any ideas on why the phone would be recognized, but no screen?
Update
Checked all the connections. All were tightly seated. Now iTunes won't recognize phone at all, which I assume means the phone is not turning on. May have to take it to a repair shop as it seems there is more going on than just the LCD screen.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Also check if iphone may be set to DFU mode
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
It will most likely be a loose LCD connection. Either that or you have damaged the connections during the tear down. Try taking off the metal plate on top of the LCD and Digitiser connections and re-sit both connectors. Also look at the copper strips inside both the connection and connectors to see if any are missing. Write back with what you have found and we will go from there :)
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 5,843
