Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
How to work with iPhone 5s glass without OCA layer
Hey there,
we ordered iphone 5s glasses and thought that they contain the glass, the frame and the oca glue layer.
Unfortunately there is no OCA layer on the inside of the glass. So we can not connect the glass with the lcd.
Do we have to buy those OCA layers seperately?
Do you have some solutions or links?
Thank you for the response!
Onur from Mobile-Box
Thanks a lot
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
You have a couple options. you will need and OCA layer whether you buy it separate or pre installed. You want to be careful as well with what OCA you get. You will want to get Mitsubishi brand. There are multiple types of screens that companies offer.
2in1- Glass and Frame (the one you have now)
3in1- Glass, Frame and OCA (the one you want)
4in1- Glass, Frame, OCA and Polarizer (do not go this route)
you will want to find 3in1 screens, the reason you don’t want the 4in1 is because the polarizer has to be laminated almost instantly and is not very forgiving with air bubbles. Below is a link to the screens that we use
https://www.mobilesentrix.com/glass-with...
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
You can buy the OCA glue (sheets) online in many places but if it were me, I’d return the glass and purchase the display already together. Ifixit carries these and used at a very reasonable price. The reason I suggest returning the glass only is that if it is not done absolutely perfect, you wind up with bubbles or worse in your display.
iPhone 5s LCD and Digitizer
iPhone 5s LCD and Digitizer Görseli
Ürün
$39.99
Puan 0
Yorum Ekle
Considering your name is rfurbishman I'm assuming you are wanting to do screen refurb on many different screens and not just one. You received a 2in1 glass which is the glass and frame what you need is a 3in1 which is glass, frame and OCA then there is a 4 in1 which is glass,frame,OCA and polarizer do not get this one because the polarizer bubbles are very unforgiving. Mobilesentrix has good 3in1
Puan 0
Yorum Ekle
Yanıtını ekle
Onur Derya sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 67
