Ana içeriğe geç
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 Soru Tümünü görüntüle
iMac backlight only on lowest setting (LCD panel or Inverter defect?
hey guys, I have an iMac 2011 27 inch. The problem with this iMac is that the backlight only works on the lowest setting. If I increase the brightness the screen will go black, but the desktop is working because I can see it using a flashlight. The icons and desktop is visible with a flashlight.
GPU is probably working. Using an external monitor does not have this issue.
Diagnostic LEDs 1,2,3,4 are on.
Do you guys think it is the inverter or the actual LCD backlight itself ? thanks
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Apple Part # 661-5980A
https://www.dvwarehouse.com/661-5980-App...
$24.95
iMac Intel 27" EMC 2429 LED Driver Board Replacement
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Hello Mayer, I forgot to mention that I fully disassembled the LED panel and there were some bad LEDs in the backlight itself. I tested all LEDs with a multimeter in diode mode and some didn’t even light up.
tarafından
Yorum Ekle
Yanıtını ekle
John sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 153
