Ana içeriğe geç
Surface Pro 4'ün halefi olarak Haziran 2017'de piyasaya sürülmüştür. Microsoft Surface Pro 12,3" olarak da bilinir. Model numarası: FJT-00001.
Bad battery, need to replace
Hello. I think I may need to replace the battery in my Surface pro 2017 if it gets any worse. Two years after I bought it I only get 3 hours of battery life. I see you have a surface pro 4 battery replacement video but I can’t find any specifically for Surface Pro 2017. Do the video and the tools for the Pro 4 also work for the Pro 2017? Any advice would be appreciated. Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
2 Yorum
My customers surface only turns on when connect to charger
tarafından
I bought a new battery ($50+) then cracked the screen ($200) and then broke the LCD touch screen connector ($10) which I am waiting for. So I’m in it for $260 to “change the battery.” Couldn’t find a place that would do it because the screen tends to crack. Not sure what I would do better next time but you may factor these costs in in making your decision to replace vs. buy new one. I had the same experience as you as far as battery life. I ended up buying a new Surface Pro 7 and am going to use my old one as a back up.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@ilikegreen I would suggest to follow the guides and teardown from here After that proceed carefully the same way as the Surface Pro 4.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Thanks for the advice.
tarafından
I do not see a battery replacement guide help!
tarafından
Yorum Ekle
Yanıtını ekle
Richard Paulino sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 31
Her zaman: 1,997
