Ana içeriğe geç
The Garmin Nuvi 200 is part of Garmin's 200 series of GPS navigators. It was released in May of 2007. It comes with preloaded maps of the entire continental U.S., Hawaii, and Puerto Rico. It is available in classic silver or pink.
Disabling usb mass storage mode
Recently I plug my USB cable into my computer and now I cannot get USB mass storage mode off my garmin nuvi 200w
Bu iyi bir soru mu?
Puan 5
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
The information provided is from here and explains why it does that. "Garmin Mass Storage Mode devices no longer communicate with a computer with the Garmin Protocol but instead present themselves as a USB mass storage device. When a USB cable is connected between a Garmin Mass Storage Mode GPS device and a computer, the GPS device enters mass storage mode." so you could try the reboot by :
1) Disconnecting the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi should now reboot, but remain in GPS mode!
The only other thing I can think of is that you might require a new cable, if this just came up. Good Luck and I hope this information helps.
Bu yanıt yardımcı oldu mu?
Puan 20
15 Yorum:
Thank you much for this fix!!!! It worked!!
Kathleen Marie
tarafından
you are very welcome ;-)
tarafından
Thank you, oldturkey03. Save me $$$.
tarafından
@Mark Koh, you are welcome.
tarafından
worked by pressing and holding it for a few seconds- thank you
tarafından
10 tane daha yorum göster
Yorum Ekle
I have Garmin Nuvi 260w GPS and Have a similar problem I did and fallow all the direction from Steps 1 to 4 as stated above ,GPS started showing running Visual Maps directions ONLY . Great. better than nothing ?
But found Talking Direction is stop working , GPS DONT want to Speech ? . I checked GPS Volume, Sound Settings, i.e. sound is Abled or Disabled, it is abled and also Couple of time switching either way but GPS Don't Give Voice Direction. It Works and Gives Both Sound/Visual Directions together at the same time before performing Fix steps 1 to 4. That means when working all alone on GPS battery and not connected to Car at all> Please advice if you good guys have any solution ?. Abee
Puan 0
1 Yorum:
Thank you so much. Was ready to throw in the garbage and never buy a garmin again.
tarafından
Yorum Ekle
Yanıtını ekle
mona sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 24
Her zaman: 41,078
