GE TBX19JAXCR leaking out the back around funnel drain
HOW DO I GET TO THE INSIDE OF THE FRIG TO CHECK THE FUNNEL DRAIN FOR blockage or whatever is causing the water to spill out around it.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Here’s a video on disassembling it:
https://www.repairclinic.com/ProductDeta...
Solution 1:
Clogged or Freezing Defrost Drain
The defrost drain might be clogged or frozen. If the defrost drain is frozen, the water will overflow the drain trough and drip down to the bottom of the compartment. If the defrost drain is frozen, thaw it out and ensure that the drain is clear of debris.
Solution 2:
Drain Strap
Some defrost drains are outfitted with a drain strap. The drain strap is a small piece of copper or aluminum that attaches to the defrost heater and extends partway into the defrost drain. When the defrost heater turns on, heat is conducted through the drain strap to melt away any ice that may have accumulated further down in the defrost drain. If the drain strap is not in place, the defrost drain may be more likely to freeze over.
Bu yanıt yardımcı oldu mu?
no need to get inside. Remove drain tube on back of refrigerator, twist the drain funnel about 45 degrees and pull. now you can clean drain the and the drain funnel. it is actually a trap and looks like sideways “S”.
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 271
