Ana içeriğe geç
Repair and disassembly guides for Garmin GPS devices.
Replacing the digitizer glass
I just purchased a replacement glass for my Garmin Edge 800, but it is just the glass and not the glass in the frame. How do I remove the cracked glass from the frame and install the new one? The original appears to be glued to the frame
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
@dwiener
use a good hair dryer or a heat gun on its lowest settings. Move the hot air along the sides of the digitizer to soften the glue. Once soft, use a thin tool to replace the digitizer.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
I’m trying a hair dryer. The case is getting hot, but the glue doesn’t appear to be softening. About how long should it take?
tarafından
@dwiener big depends on the glue they are using. It is most likely a adhesive strip. Try a guitar pick and loosen it when the heat is relatively high without melting the case.
tarafından
Yorum Ekle
Yanıtını ekle
Dennis Wiener sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 478
