Is the screen digitizer attached to the LCD?
Wondering if I can just buy the LCD alone, or have to get the LCD+digitizer assembly, as the touch still works fine, just the LCD is cracked
Bu iyi bir soru mu?
Bu iyi bir soru mu?
tipoo the digitizer and the LCD are separate pieces. You can replace one without having to replace the other
Bu yanıt yardımcı oldu mu?
Yes, I do believe this tablets digitizer is attached to the LCD. It would be recommended to replace them both rather then try to do an at home adhesion if that is the case. I attached a screen repair link below and it does show two pieces at the end. however I cannot tell if the white frame is a digitizer or just a cover.
Might want to drop that author a message.
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 92
