Ana içeriğe geç
26 Ekim 2018 tarihinde piyasaya sürüldü. Modeller: A1984, A2105, A2106, A2108. GSM veya CDMA / eSIM, nano-SIM veya çift SIM seçenekleriyle; 64, 128 veya 256 GB depolama kapasitesiyle; Siyah, Beyaz, Mavi, Sarı, Mercan veya Kırmızı renk seçenekleriyle sunulmuştur. ("iPhone 10 R" şeklinde okunur.)
How to replace : iPhone XR Rear Camera Lens Cover
Will heat release the glue of the. Lenses COVER.? I bought the lense cover but I can not find anything as to how to remove just cover by itself!?, anyone have a step by step guide or a video that you have discovered?
Thank you,
papa
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
1 Yorum
I used a paper plate cut a hole out the size of the rear lense and used the tip of a regular iron and kept the body of the iron away from the phone! Once it was on for about 5 seconds I used a single edge razor blade to remove small bits of glass from the ring. I immediately vacuumed any debris from the phone or the paper plate i had below the phone!
2 paper plates, iron ( no steam ) alcohol to clean camera, vacuum cleaner, jewelers glasses, white light!
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The glass is stuck on there really good and just heat will not help much. The glass will just keep breaking while you remove it and some will get inside. The best way to do this is by taking apart the phone and removing the camera to be able to prevent it from getting damage. You can also try using a small tip vacuum cleaner right at the camera while prying out the glass bit by bit while keeping it warm so it doesn’t end up falling in the camera.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Did anyone ever answer this? I also got a lens with cover when ordering the part.
can I remove the lens housing from the Backglass without cracking the back?
Puan 0
Yorum Ekle
I bought a Replacement lense with the iron ring around it.. how can i replace that?
Puan 0
1 Yorum:
The problem is i bought the full lens with metall ring…
tarafından
Yorum Ekle
I replaced the lens without taking the phone apart.
Somewhere someone recommended using a utility knife and carefully breaking the lens out piece by piece.
I did that with a utility knife and finished up with an X-acto knife. It worked fine for me.
Puan 0
Yorum Ekle
Yanıtını ekle
Get Up & Go Now sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 15,092
