E :62 :10 what is this
There is always E:62 :10 on the screen of my camera whenever i open it, can someone please help me, am gonna join a competition and i want to use this, pleaaaase…. URGENTTT?????
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Andrea Kim that is a lens error. Could be generated by a stuck lens. Try to extend the zoom immediately after you turn the camera on. Then remove battery while still in zoom tap around battery case a few times.Then replace the battery and see if that will help. If not you will need to either repair the lens or replace it.
Bu yanıt yardımcı oldu mu?
Hi,
This is a very well known and recurring problem that happens a lot with Sony camera's.
Error messages can be found at https://www.sony.com.au/electronics/supp....
E:62:10 is a generic error of the stabilizer. All users experience the same process : after less than 3 years of use the stabilizer breaks down, making it impossible to take sharp pictures, and displaying the dreaded E:62:10 error message.
Thousands of users on the Internet have the same problem, read the complete explanation with more than 400 forums listed on the website '''http://sony-e-62-10.atspace.cc/''' ! or just search E:62:10 on Google or on Google Videos or on YouTube !
A temporary solution could be available at https://www.youtube.com/watch?v=S53D3EfD....
For me it is a hidden defect or a problem of programmed obsolescence which Sony refuses to follow up despite the many complaints.
If your camera is still under warranty, get it fixed or replaced as soon as possible.
Otherwise, I advise you to take contact with the support services of SONY, and keep us posted of the evolution of your case.
Son 24 Saat: 4
Son 7 gün: 18
Son 30 gün: 115
Her zaman: 5,094
2 Yorum
Same problem, contacted Sony support who advise a repair at £54 per hour for labour, but no indication of how many hours it would take, anymore more than two would make it uneconomical, any other ideas
Alan Crookes tarafından
Hello, sorry to hear that. To answer your question, take a look at the section "Root cause analysis" of the website ''http://sony-e-62-10.atspace.cc/'' dedicated to this problem. When the problem happens under warranty, SONY replaces the flexible ribbon that is responsible of the structural failure, but out of warranty most repair shops simply replace the full optical block and then it costs a significant amount of money nearly similar to the purchase of a new device. On the website there are also references of other public videos on Youtube showing the repair process, that will give you a more precise idea. Hope this helps.
Rodolphe Olivier tarafından
