Charging Issue since 4 months
Charging with low power only, heat up. Not charging while shut down.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You likely need a new battery set the main battery is easy to replace following this guide iBook G4 12" 800 MHz-1.2 GHz Batarya Değişimi You also need to replace the PRAM battery which is located under the top shield just behind the ports. Follow this guide to gain access iBook G4 12" 800 MHz-1.2 GHz Üst Koruma Plakası Değişimi. The battery guide has the info for the button battery.
Kılavuz
Zorluk:
Çok kolay
Kılavuz
Zorluk:
Zor
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 296
