Ana içeriğe geç
{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
Why my touchbar have a purple tint around the icon?
I have an MBP 13" 2017 , which recently started showing a purple tint around the touch bar icons. It looks there is some sort of issue with it, as at times it just fades and flickers. Every function on the touch bar works as it is supposed to but there is some kind of issue with it.
I have tried booting in safe mode, resetting SMC, NVRAM but the issue is still there. Finally, after a few chats with Apple support, I completely wiped out and did a fresh install of the OS. And after everything, the issue is still there. So it looks like it is some sort of hardware related failure.
Bu iyi bir soru mu?
Puan 3
2 Yorum
Having the same issue on just 15 days old machine. I got 16 inch MacBook Pro on 6th January 2020 and experiencing the same issue now.
tarafından
@Erick Bassan - Time to visit an Apple Store or authorized service center
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I’m not very familiar with touchbar build, but I’d say you’re definitely right, looks like a hardware issue. Hard to tell if it ‘s the touchbar itself or some circuit feeding power/data to it. I’m afraid Apple would charge an arm and a leg to fix that. The other alternative would be find some independent lab into component level repairs but that’s not going to be very cheap either. It’s a bit alarming such a thing may happen on a less than 2 years old machine.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Bara Limbong sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 672
