LCD leak bezel or lcd itself?
My Powerbook's screen is leaking pretty badly at the bottom to the point it's distracting. Is the problem with the bezel or the lcd itself? Which do I need to replace?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
There's nothing in the bezel to leak. This sounds like you've cracked your screen. Here's how to replace it: PowerBook G4 Aluminum 12" 1-1.5 GHz LCD Replacement
Here's the part that iFixit has. I would look at the back of your screen and contact them to make sure the replacement will work.
[bağlı ürün eksik veya kapalı: IF153-082]
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 582
1 Yorum
Thanks, I meant light leak on the surface of the lcd itself. I assume the fix is the same -- a new panel. Thanks.
les tarafından
