Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2265 Soru Tümünü görüntüle
Help with Glass only screen repair (Not lcd repair)
I have done many repairs before so I am not a total noob however I have just recently attempted to do a glass only screen repair on an iPhone 7, I got the glass of perfectly without problem but the glue that remains on the lcd seems impossible to get off without breaking the lcd even though im using 99.9% isopropyl alcohol. Any tips on how to overcome this? thanks in advanced.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum:
Just use the adhesive removal tool it's a heated scraper that cut through the glue.
Changing just the glass without all the tools required to do so sure seems like a total noob thing to do lol
tarafından
I have been trying to use that and i feel like I’m having too scrape way too hard to get any adhesive off
tarafından
Is it a handheld one or a proper one??? Make sure its heated enough... it should all just come off fairly easily, there is a chinese debonder liquid available that dissolves the glue as well but u have to be careful with it as it gets between the backlight if u havent removed that...
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
It could be that you are trying to take the polarizing layer off in which case you would have to fully remove it and buy a new polarizing layer. If not, try using acetone.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Haris sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 6
Son 30 gün: 6
Her zaman: 59
