Ana içeriğe geç
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Soru Tümünü görüntüle
CPU fan running at full speed while fan control shows 0 rpm
Hello there guys,
So I've recently baked my GPU and it works like a charm, but during the process I accidentally ripped my GPU thermal sensor cable.
I've plugged loose sensor cable back to the board, but it is not attached to my GPU.
Now ever since my CPU fan is running at full speed but fan control software shows my CPU fan running at 0 rpm without any option to control it (I can control ODD and HDD fans though).
I have tried resetting and upgrading my SMC, tried upgrading EFI as well without any luck.
My question is does lack of my GPU sensor affect my CPU fan or the problem is elsewhere?
Thank you for your time!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Simple answer - YES!!
What you are seeing is SMC has gone into Safe Mode to protect your system from overheating. When any thermal sensor becomes disconnected this is what happens.
You’ll need to fix the GPU thermal sensor.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
krauut sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 1,184
