Ana içeriğe geç
Motorola Moto Z3 Play, Haziran 2018'de piyasaya sürülmüştür. 6 inç ekrana ve çıkarılamayan 3000 mAh Li-İyon bataryaya sahiptir. Arka kamerası 12 MP, ön kamerası ise 8 MP'dir. Model numaraları XT1929-3, XT1929-4 ve XT1929-8'dir. "XT1929-3 NA XT1929-4 NA XT1929-4 NA XT1929-5 LATAM XT1929-6 LATAM XT1929-8 EMEA/APAC"
Screen replacement causes digitizer to not work
We are a repair shop and we have tried replacing the screens on this model a few times xt1929-17 and every time the digitizer doesn’t respond on the new lcd has anyone experienced this issue or come up with a fix?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 10
Yorum Ekle
2 Cevap
Filtre ölçütü:
I am also experiencing this issue! The digitizer stops responding once you turn the phone off and then back on… it’s a little annoying to say the least. Any guidance on this would be awesome!
Thanks
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
I’ve researched and asked local shops as well most have just blamed it on the current quality of the parts on the market being low. Are shop has suspended repairs at the time do to the large warranty rate of the XT models
tarafından
Yorum Ekle
You have to do a hard restart. It’s the only way I’ve found to do it.
Puan 0
2 Yorum:
Could you clarify how you did that? I had the battery cable disconnected, replaced the screen with no problem, and turned the phone on without issue. The problem is that the touch doesn't register, no matter how many times I fiddle with the battery. This was a straightforward, easy fix up until this point.
tarafından
When he says hard reset, he's likely referring to a factory reset.
I haven't replaced the screen on this device yet, but I plan to soon. I'll let you know if I run into this issue and have I might fix it.
tarafından
Yorum Ekle
Yanıtını ekle
Mike Henry sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 1,311
