Ana içeriğe geç
PS4 Slim HDMI Filters
I recently had a ps4 slim with no signal, I swapped the hdmi port, I also had to swap a couple of HDMI filters (I dislodged and lost them) I bought some what where advertised on ebay as PS4 slim/pro HDMI filters, and although they were a little big I managed to get them in. I now have a signal but its was something like 640 x 480, it was mainly black but had a couple of colored lines up one side of the screen. I think replacing the filters would fix it but I’m having a real issue sourcing them, which is making me question if its at all possible to buy them?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Was the previous port not physically damaged? I’m thinking the problem would be caused by the HDMI encoder IC instead.
The dislodged part makes it a bit tricky as that can be caused by bad solder joints / connections behind the HDMI port pins.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
No damage that I could see, it was getting no signal, I swapped the port and 2 HDMI filters, the HDMI filters where sold as PS4 slim filters, these are slightly smaller and I think were falsely advertised because the one I have put in look like they have come from a standard PS4. Since the change I now do have a signal but its of a black screen (fuzzy) and a couple of colored lines.
tarafından
Yorum Ekle
I have the exact same problem. Did you ever find the correct one's for the slim?
Puan 0
Yorum Ekle
Yanıtını ekle
Steve Fishwick sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,012
