Ana içeriğe geç
Repair information for hot tubs.
35 Soru Tümünü görüntüle
Brand new hot tub will not work
I have a brand new 2019 Catalina Burkeshire six person spa. All the electric has been hooked up correctly with GFI and other required parts. When the breaker is turned on the LED lights come on and the stereo comes on but the pumps will not engage. What is the problem or what can we try to correct this ?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Hey Jeri.
Did you make sure the T Stems on the "Slice Valves" were locked in the open position before and/or at the time the electrical power to the unit was first turned on? If one of these valves was closed at that time there may have been immediate damage to the spa.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The troubleshooting guide for your spa lists these steps to take if pumps are not working: Air lock - check that pumps are bled of any air.
Pump cycle has ended - press button to turn pumps on.
Slice valves closed - open slice valves.
Check power - check connection in spa control box.
Update (07/21/2019)
Here is a link to the owner's manual:
https://www.google.com/url?sa=t&source=w...
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Jeri sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 48
