Ana içeriğe geç
The Panasonic KX-TGEA20 is a phone accessory that is compatible with Panasonic devices. It features a 1.8-inch LCD display with a resolution of 103 x 65 pixels. The navigation key allows for easy and convenient use of the phone.
3 Soru Tümünü görüntüle
Phone goes off after one incoming call
Phone will only ring once and then goes off
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum:
Hi,
Just clarifying.
The phone rings once and then stops ringing. Is this correct?
Is there anyone there if you answer it after the one ring or not?
Can you call out OK and if so is the line noisy?
tarafından
My phone rings off after one ring no one there if they ring back it might take a few times before we can answer them We can ring them there is no noise when we do
tarafından
Hi,
Have you got access to a corded phone that you can plug into the phone line instead of the Panasonic just to check if the problem is in the Panasonic phone or whether it is connected to your phone service?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Maybe it’s a battery problem. You might want to check it if it can still supply the power needed. If not, you may consider replacing the battery?
Cheers.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
sheilajohn-49@hotmail.co.uk sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 1,230
