How to determine compatibility with a 15" MacBook Pro7,1
I am in the process of researching to what extent I can upgrade my Apple Refurbished 15” mid 2010 MacBook Pro with Model Identifier 7,1. My question arises because apparently there is no such thing as a 15” 7,1 model. I am guessing the refurbishment of my machine is the cause of this discrepancy.
Processor: 2.66 GHz Intel Core 2 Duo
Memory: 4 GB 1067 MHz DDR3
OSX 10.6.8
I want to upgrade the OS to the most current possible, the RAM (to the highest possible), and the HD to at least a 1 TB SSD. I also need to replace the battery and possibly the trackpad.
I understand that 15” mid 2010 MBPs only officially support 8 GB RAM; only the 13” models support 16 GB. How do I determine the official capacity of my machine?
When attempting to determine compatibility with an SSD or any other parts, how do I know what will work when my machine falls in between categories? I am only barely computer literate. Is the reason my machine falls between categories because of a difference in the motherboard?
Any guidance would be greatly appreciated. Thanks in advance!
Bu iyi bir soru mu?
2 Yorum
Try this open 'About This Mac' It will also tell you what your system is. Post an snapshot here for us to see too!
You can't fit a 13" logic board in a 15" system so something is not correct here.
Dan tarafından
Thanks, Dan - I finally figured out I was just plain wrong... I had it in my mind that my machine was a 15" (I bought it so long ago and just changed my mind along the way) and even measured it diagonally across the screen (like a TV) to see it was exactly 15." Now I know that is not how MBPs are measured, finally checked the dimensions on the Apple spec page. I know there is no such thing as a stupid question, but I feel more than a little stupid for my wrongheadedness with this question. Thanks for taking the time to answer.
Matthew tarafından
