Ana içeriğe geç
Sony XBR-65X850D, LED arka aydınlatmaya ve 2160p çözünürlüğe sahip 65 inçlik bir LCD Ultra HD TV'dir. 2016 yılında piyasaya sürülmüştür. Model numarası: XBR-65X850D.
How do I remove the back panel
How do I remove the back panel? I have removed all of the screws, but along the top of the plastic cover, it seems to be clipped in. I don’t want to force it and break something. I’m trying to remove the cover that the main board is under.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
How to open back 65x 900f sony tv
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@corecrash yes it’s a bit tricky and here are the RIGHT instructions for it. The previous once were for the 850C
Resim
Resim
Bu yanıt yardımcı oldu mu?
Puan 6
3 Yorum:
This is not X850d!
tarafından
I am also very confused.
tarafından
@desertkiwi corrections made. Sorry the previous instructions were actually for the 850C. See if these instructions make sense to you. Good thing you commented otherwise I would have never known.
tarafından
Yorum Ekle
Once you have all the screws out from the back you want to wack the panel from the bottom towards the top of the tv. Essentially there are fixed screws that the back panel is resting on like a picture rests on a screw in the wall. So you want to push it up in the same plane as the tv panel. If you force the back away from the tv you will break those snaps. There are around 4 or 5 screws across the you inside the cover so it can take a lot of controlled force to knock the panel off the screws.
Puan 5
1 Yorum:
I still have difficulty to open it by this method. Do you have any video or picture instructions?
tarafından
Yorum Ekle
I had this problem too. Umair Khan is correct. You need to remove the screws and push the back panel upwards. It was quite hard and I didn’t want to break the panel, but it eventually worked. There are six screws at the top (pic below).
Resim
Resim
Puan 5
Yorum Ekle
Make sure all the screws are removed. You also need to remove the power cable. I’ve never worked on this TV before but a lot of them share the same features. Maybe your TV is like this version: https://youtu.be/2WtDCYjp2kg
Puan 1
Yorum Ekle
remove any screws you see, including the power cord. on the bottom, by both corners there are two plastic tabs. take a screwdriver and gently pry them out. (any screws!) will prevent it from "unlocking". The tabs will slide out about 1/2". Now swing the bottom out and lift up to unhook it from the top section.
Puan 0
Yorum Ekle
Yanıtını ekle
Mark sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 53
Her zaman: 13,220
