Ana içeriğe geç
Xbox One Stereo Headset, model number B00IAVDQCK. Released March 2014, compatible with the Microsoft Xbox One. Headset includes over-the-ear fabric ear cups, unidirectional boom microphone, and detachable headset adapter with volume and mic controls.
30 Soru Tümünü görüntüle
How to combine an Xbox One Headset with Working Audio Jack
I have two headsets, one with broken jack and other with working jack, so I want put the working jack on my good headset. However the two headsets have different wiring colors and I don't know which wires to connect. The jack is coming from a microsoft headset where the wire colors can be confirmed here: ++What wire colors are in the TRRS 3.5mm jack?, and the headset I want to connect it to is a Nubwo N2 which I can't find anything about. The Xbox jack has white, black, red, and blue wires (top), while the Nubwo headset has white/copper/green, blue, red, and red/yellow (bottom).
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
do you have a multimeter ?
tarafından
I do not have a multimeter
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Ok take a double AA battery 1.5V and 2 random wires then connect them together, hold one side with your finger and the other one connect/disconnect it every 0.5 second, and in the same time put the headset on your head and try to listen which one is making a tiny noise, try the 3 different combination until you find out the common wire (Ground), you can even here them together.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Robert Johnstone sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 392
