How does one fix a power window that does not go up or down
how does one repair a window that does not go up or down in 2005 equinox
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The motor that drives the window regulator may be faulty. Or the switch may be bad. You’ll need to pull the door interior off and explore the window motor wiring harness for proper voltage and operation from the switch. If this is a rear window, make sure the lockout switch on the drivers door isn’t engaged. Most new cars have that and it always get inadvertently overlooked and engaged.
Bu yanıt yardımcı oldu mu?
It’s often broken wires between the door and post. Open the door, and pull back the boot surrounding the wires.
I am dealing with a 2012 that has no power to window motor but power to door lock and radio sends sound to door speaker
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 1,350
Do you hear a motor spinning or any other noise when you toggle the switch ?
Vertinhol tarafından
