Ana içeriğe geç
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
I put the hd temp sensor in wrong.
I recently put in an aftermarket SSD into my imac with an SS+HD configuration but must of put the hard drive sensor in wrong, because the fans are going full blast. Does anyone know the proper way to connect it? Thanks@
Bu iyi bir soru mu?
Puan -1
1 Yorum
Did you change the hard drive?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Fixed it, the sensor needs the black wire facing up, with the wires over the 2 pins closest to the sata/power cables. And for the last time, if your adding an ssd and keeping the appl drive, you will NOT have a fan issue.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
ekimia1987 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 933
