Ana içeriğe geç
Kasım 2016'da piyasaya sürülen PS4 Pro, 4K oyun ve iyileştirilmiş PSVR performansı için yükseltilmiş donanıma sahiptir.
Rear USB Damaged, replace?
My USB on the rear of the PS4 Pro got damaged. (Wait for console to cool down before removing rear cables) I paid for an Xtra 3 rear warranty (was in warranty when happened) but was told I broke it so no repair.
The USB port had either shrunk or the cable expanded. When I removed the USB cable, the port came with it. As in the plastic piece that covers the ports pins. When I tried to reconnect it not knowing what happened the pins got bent. I tried to fix them after I was told I wasn't covered.
Now year later I have two ports. But one is the external HDD the there is my TAC for mix and headphones. I miss the 3rd USB. If I connect the HDD to one USB and use the other for say a USB hub. Will this be better than fix it by the rear USB. Also does the PS4 have enough power for the port. Or do I need a powered hub?
Steering wheel, Camera, controllers and other devices. I have USB hubs with there own socket. But some devices need to be connected to the PS4.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
You’ll need a externally powered HUB, one that comes with a DC port on the hub to power it externally. USB 3 / 2 is fairly limited in supplied power 0.5A/1.0A.
These ports are USB 3 capable so you might be able to get away with the use of a USB 3 hub that is directly powered off the PS4 if you’re lucky.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Caleb Mac Donnchadha sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 1,619
