Ana içeriğe geç
25 Ekim 2015'te piyasaya sürülen Afterglow Prismatic Kablolu Kontrol Cihazı, video oyunu aksesuar firması PDP tarafından üretilen bir Xbox One kontrol cihazıdır.
Not Turning on at all
No matter what i do, it will not turn on what so ever, i’ve tried to cord, works, i’ve tried undoing updates on the xbox, nothing. When i plug it in the light above home button flickers and still nothing. When i hold the bottom dpad the light stays on, and starts turning off and on again, but led’s arnt turning on and i cant do anything. I desperatly need help.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
I recommend getting another controller and seeing if that works. You could just be one of the unluckier folks and have a factory defect controller. If the new controller doesnt work as well, then try using a different USB port. Sometimes the connection in the USB connectors can be a little funky. If all else fails, just use a different (OEM) controller.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
It's the controllers micro USB port.
I sprayed some electrical component cleaner in it, plugged it in and unplugged it multiple times (to get the cleaner to penetrate and clean the contacts) then wiggled the cord end at the port a few times, started working again.
I've even unplugged and plugged it back multiple times, works like a dream.
Hope this helps someone else!
Puan 0
Yorum Ekle
I have this controller too,
Try wrapping the wire around the front of the controller (over the home button then down) two times
This may work but it may not at the same time
Puan 0
Yorum Ekle
Yanıtını ekle
Ben Gaming sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 40
Her zaman: 2,429
