Ana içeriğe geç
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
Help 4l60e constant shifting
97 chevy 5.7l vortec. Backfired through intake and blew pcv valve line off the intake. Drove it 20 miles not knowing it was off, abnormally high idle. Reconnected line now i get a back and forth 3rd to 4th gear shift. Rpm amd speedo jump around when this happens. Rebuilt trans 6000 miles ago. Tested all solenoids in tranny, all good. No Cel no stored codes. Any ideas? Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Also it doesnt always do this, sometimes it does perfect. Other times it does it right off the bat from first start up.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hey Lee.
Could be throttle position sensor issue (harness and/or wiring included). Throttle plate could have carbon buildup around it’s edges, as well. Also make sure vacuum lines and connections are sound.
Hope this might help.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
It did throw a tps code 1 time and 1 time only. Erased it and it hasnt came back. I will replace the tps and see what happens.
tarafından
Yorum Ekle
Yanıtını ekle
Lee stevens sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 139
