Ana içeriğe geç
Boost ve Virgin Mobile için model numarası LS676.
Issues with safe mode and power button
My phone completely froze. So I popped the back off, removed the battery, waited and then reassembled it. When it restarted, it was in safe mode (never had it happen before). I swiped the notification bar down and clicked the option to exit safe mode. My phone restarted and I then chose how I wanted to restart it. I chose home & app drawer (what I normally run). My phone loaded up fine and I have access to everything once again. However, now the power button doesn't respond. I mean, I can still turn the phone on and off by double-tapping the screen, but can't take screenshots or use the power button in any way. Please help.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi Stephanie
The problem is definitely with your power button. With the type of failure you’re having I’m guess some type of water damage. Luckily this phone isn’t too hard to work on and the power button is a cheap replacement. I would recommend going for it!
If you find any water damage (white corrosion) inside, you should scrub it gently with some alcohol and a toothbrush to clean it up.
Best of luck!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Stephanie Bump sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 666
