Charger Port Replacement and pulled Pads
Tried to replace a iPad air charger port, Pulled 3 pads however, Pads 3,9 and 27
soldered new port in iPad still charges, pads 3,9 & 27 are ground pads
1.) should these ground pads be connected using jumper wires? im at a loss to where to connect them
if No
does this not make the circuit open, and is it safe?
Bu iyi bir soru mu?
I agree with @propman , ground is there for a reason and most sensitive rails may suffer a lack of grounding. Choose the closest grounding spots you can find with your multimeter and make a couple of bridges to be on the safe side.
arbaman tarafından
@propman i was thinking the same too!
Eli Villie tarafından
@arbaman i haven't tested data transfer as of yet, i will try this and post what happens
