Ana içeriğe geç
Asus X200CA dizüstü bilgisayar 11,6 inç boyutunda ve 1,18 kg ağırlığındadır. Intel® Core™ i3 3217U İşlemci, Intel® ULV Pentium® 2117U İşlemci veya Intel® Celeron® 1007U İşlemci, 2 GB veya 4 GB RAM, 320 GB ile 1 TB arası depolama alanı, Windows 8 işletim sistemi, HD web kamerası ve yaklaşık 3 saatlik pil kullanım süresi ile gelir.
Screen is black, computer runs
I had tried a lot of methods I’ve read, for example the ones where I need to remove the battery and hold the power button for several seconds, even minutes, also the F2 + power button and there’s still no response. I was able to connected to my TV. I read somewhere about going to system manager and deactivate the intel graphics. I did that and then i activated them again and I was able to see both screens. I unplugged the Tv did some work on my computer then turn it off. The next day, I turned the computer back on, and was the screen again black, I repeated the method, and it worked. I just feel unnecessary to repeat this process over and over again, does anyone has an idea what do I need to do
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Are you remembering to save your changes if appropriate? Might also want to check your users manual to see if there is a function key toggle for switching between external and internal monitors.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
If you can get a display signal to your TV then I’m pretty sure the laptop screen is almost completely dead.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Javier Portillo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 294
