Ana içeriğe geç
Repair and troubleshooting information for the HP Pavilion dv6000, an HP laptop part of the HP Pavilion series. Released in April 2007.
Why does my computer show blue lights and then shuts down?
I turn on computer and the blue lights flash, the screen is blank and then it shuts down.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
sandy, check on this question. I believe that you are running into the same problem.Just to try something, make sure that you AC adapter works. You will have to have a multimeter and measure the output on the jack of the adapter. Also, remove the battery, the AC adapter and your memory modules, and wait a few minutes. Then reassemble with just one memory module and you want to try it in different slots, also try the other nodule if you have more than one. You can further try to reset your computer. The directions for this are in the service manual which is available here,
Resetting the Computer
If the computer you are servicing has an unknown password,
follow these steps to clear the password. These steps also
clear CMOS:
1. Prepare the computer for disassembly
2. Remove the real-time clock (RTC) battery (refer to
Section 5.7, “RTC Battery,” for more information).
3. Wait approximately 5 minutes.
4. Replace the RTC battery and reassemble the computer.
5. Connect AC power to the computer. Do not reinsert any
batteries at this time.
6. Turn on the computer.
All passwords and all CMOS settings have been cleared.
Give this a try and see what you come up with, good luck.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
I have tried everything on this laptop still no avail Runs just blue lights and then on a few seconds it shutdown and reboots constantly in this state
Puan 0
3 Yorum:
John, what blue lights? When you say "have tried everything", can you be more specific?
tarafından
Hi what was the solution on this problem as I am encountering the same thing with my HP Pavilion dv6000
tarafından
I am also having this same problem with my tx2000 pavilion. What is the way forward solution to solve this problem once and for all.lisa
tarafından
Yorum Ekle
Yanıtını ekle
sandy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 2,228
