home buttom replace two times but still dosn't work
why home buttom ddoesn’t work at all?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You cannot “replace” the Home Button as it is paired with the logic board and only the original will work. You can put a low-cost button but that will just “fill the hole” but it will not function at all. There is the JC Home Button that simulates the “click” function but it is not available on the iFixit store.
If you meant that you transferred the Home button and tried on two different attempts, then I would read the following:
The iPhone 7/8 series have a very inconvenient bend on the Home Button flex. It’s really easy to tear the flex, either near the logic board connector or at the 90 degree bend before it sneaks underneath the LCD heat shield. You have to be careful when you lift the screen off the first time but also anytime the flexes are connected and you have the device open.
The other area that is easily damaged is the connector on the Home Button itself and the opposite connector on the short flex that runs underneath the heat shield.
The long and short of it is that there are multiple failure points. You will need to carefully inspect the Home Button and flex to see if there is any damage. Magnification here will help. Look for tears to the flex or any physical signs of damage. You should also check the connector to insure none of the pins are damage or that there isn’t any debris.
Bu yanıt yardımcı oldu mu?
The home button is not swappable it is paired to the logic bored. But you can get a blueooth home button online and it pairs through the bluetooth in your phone
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 39
