Ana içeriğe geç
Device repair guides for the 2018 Motorola Moto Z3 smartphone, model number XT1929-17.
19 Soru Tümünü görüntüle
My display wont turn on
Okay. so today my replacement battery came in (yes)! It was definitely in need of a battery considering how the battery showed signs of swelling when I took it out. With that said, I have a new issue: the display.
My phone’s screen will no longer turn on. I tried reseating the ribbon cable, to no effect.
Has anyone else had this issue?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I have had the same issue try unplug the battery then connect the display then plug the battery in , that worked for me even after I replaced the display with a new one , if it don’t work the 1st time try it again , then ribbon sometimes is not seated so good but always unplug the battery , then connect the display then the battery . Good luck , this always worked for me.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Im having this problem i plugged the new screen in and there was a white line in the screen well i unplugged it and plugged it back in and screen doesn't come. On but the phone work's did i break the screen?
tarafından
Yorum Ekle
The LCD is extremely fragile. Removing the screen almost certainly will damage the display, no matter how carefully it’s removed unfortunately. You likely need a new screen.
Puan 0
1 Yorum:
Yea. I figured as much. I since replaced the screen, and the phone stopped working again shortly after. So I’ve moved on and got a used iPhone. I prefer Android, but beggers can’t be choosers...
tarafından
Yorum Ekle
Yanıtını ekle
William Bosco sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 654
