Ana içeriğe geç
The XV20 series of the Toyota Camry is Toyota's 6th generation of the Camry sedan.
Why does my brake pedal go all the way to the floor when pushed on?
I have a 2001 Toyota Camry. I recently had to have a new brake booster installed about 4 weeks ago. Car was driving with no issues and then a few days ago out of no where when I was coming up to a red light I stepped on the brake to slow down. The brake pedal went all the way to the floor. I had to keep pumping the brake pedal to try and slow it down. The car slowed down however it did not come to a complete stop. I had to use my Emergency Brake to completely stop. I nursed the car back home (issues continued all the way) and I have not driven it since. I checked all areas where brake fluid could possibly be leaking from and have found no leaks. I have also continued to check the main brake fluid resevoir and the level of fluid has not dropped at all. I am trying to find out what is most likely the issue and/or if the recent brake booster repair could have anything to do with the current problem
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@cubanpete702 since your brake fluid level does not change you need to check the brake booster first and then the master cylinder. Check that the pushrods from brake pedal is mounted properly and that your brake booster isconnected properly to your master cylinder.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Victor sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 434
