Ana içeriğe geç
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 Soru Tümünü görüntüle
Why is my screen green?
So I turned on my ds lite to play some games and the top screen when I loaded it up had the Nintendo logo thing in green instead of the standard black and when I checked other games the green was all over the place only the bottom screen was normal. I’m thinking it’s the lcd or if it’s something else since I never did anything to my ds to make the top screen broken. I’ve had my ds for about 10 years and it only now happened. If you know a fix please let me know.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Do you know how to search with a search engine like Google.com? The first item listed at Google show a possible fix. Geez!
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Trying to check the screen cable to ensure it is completely seated inside its port on the main board. Then check the screen again. Its possible the cable came slightly loose and could theoretically cause that effect.
Top screen ribbon cable can be weathered from all the opening and closing. If the ribbon cable's loose for the top screen, if it's actually ripped instead of loose, you may need to order a new top screen or a new DS.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Hi Ismar!
I suggest you consult the three topics below that are resolved.
They are all problems with the green coloring of their screens.
One second of green light then off, was working fine, but......
top screen shows image-but with green colouration
The DS won't turn on. Green light flashes for a second..
Puan 0
Yorum Ekle
Yanıtını ekle
Ismar 123 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 36
Her zaman: 1,147
