My laptop is not turning on
Ok so I left for this morning and left my laptop on hoping it would go to sleep it did now it’s not turning on
what do I do this laptop is just problem upon problem
p.s it was connected to monitor and was left on charge
Bu iyi bir soru mu?
I take it the computer won't boot up from a total shutdown and not just from sleep mode and nothing is displayed on your screen when attempting to boot up. (that point is not clear from the contents of your query) If that is the case then you need to either try a replacement charger or use a multimeter to check your current charger is working properly and also the battery voltage. You can try taking out the battery and seeing if the computer will boot from the charger itself.
prop man tarafından
Don’t I have to remove the back panel and pull the battery out. Is it not put in the laptop with glue
Waqas Choudhry tarafından
Hi,
Here's a link to the ifixit Acer Nitro 5 AN515-53-55G9 Battery Replacement guide which may help.
jayeff tarafından
