Ana içeriğe geç
The Grand Prix was updated for 2004 on a revised version of the GM W platform and was unveiled at the 2002 Chicago International Auto Show on February 7, 2002 as the Grand Prix G-Force Concept.
20 Soru Tümünü görüntüle
Why is my car dying while I am driving down the road?
As I am driving down the road my car will just die. I lose power steering and power brakes. Once I pull over it will turn back over and start. Sometimes it sounds like the starter might be sticking when I try to turn it over to start. So I'll know it wont run right if it does that and I will turn it back off. Eventually it will start again but may die at any time driving.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This sounds like a failing or corroded electrical connection. Take it in to a auto parts store that offer free computer read out to help with the diagnostic. AutoZone is one that does it.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Could be dirty fuel
When was the last time it was serviced ??
It may need a service filters , oil etc
Puan 0
2 Yorum:
I use the middle grade of gas. Sometimes when you try to restart it, it sounds like the starter maybe sticks a little. When it does this I have to turn it back off because I know it will die again while driving.
tarafından
The starter is there to start the car After that it does not come into play at all
It would have nothing to do with the car stopping
It may be the started is stuck
A service by a mechanic I be thinking will solve this issue and ask him/her to inspect the starter
You should get it serviced because block air filter could easly cause the issues you are having and that means not starting or very difficult to start
The engine is not getting enought air throught the air filter
It could also be the injector plugs
tarafından
Yorum Ekle
There is a recall for the ignition turning off while driving it.
Puan 0
Yorum Ekle
Bring it to a mechanic. There could be many thinks causing this issue
Puan 0
Yorum Ekle
Yanıtını ekle
juliestokes31035 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 364
