Ana içeriğe geç
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Soru Tümünü görüntüle
Soru Kapandı
What kind of glue Apple uses in iPhones?
I'd like to know what kind of glue Apple uses to stick the bezel to rear housing. They dont use epoxy, Apple uses a light blue adhesive the same that used to glue the touch screen. I mean, I know the touch screen is sticked with de 3M stikers, but they uses a little bit of this kind of glue to strengthen it.
I know this same question was made several times but it seems that nobody knows what exactly this glue is?
It is not an epoxy one, this glue is soft, strong and can easly be removed with the heat gun.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
10 Yorum:
I'd love to know this... the glues I've used don't give a good finished look when you replace the rear housing.
tarafından
I found this http://www.ebay.co.uk/itm/New-Ruderer-L5...
What do you think? I guess is more easy for you to test it since I live in Argentina. LEt me know please... Thank you
tarafından
it's interesting! think it'd be good for digitiser, but I don't think it's what you wanted it for.. the bezel. I'm try "no more nails" by unibond..dries clear, but not sure it gives a strong enough bond. wasn't happy with the last glue
tarafından
i think we're looking for a silica based glue.
tarafından
I agree. I found in modmyi.com, a comment about using a silicone gasket, and i saw this http://www.permatex.com/products/Automot...
tarafından
5 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Did you try looking at Locktite 242. It's extremely pliable yet can handle constant vibration without cracking or loosening. Which are all desirable qualities when dealing with mobile products that have tendency to be banged around or even dropped.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
I will try and let you know. Thank you
tarafından
Yorum Ekle
i Spoke to someone at apple and what they use is an apple branded glue . They have there own chemist , and with that they make one of a kind glue to use .....what it contains , or what it is i don't know but I'm also looking for the same thing .....
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 6,151
