Ana içeriğe geç
Drying slowly fix or replace?
My dryer is about 10 years old and is not drying like it used to, would it be better to try to fix, maybe the heating element, or with it being this old is it better to replace it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Solution 1:
Air Flow Problem
If the vent is clogged or partially clogged, it will restrict the airflow through the dryer, substantially increasing the drying time. To ensure proper dryer performance, you should clean your dryer’s venting system at least once per year.
Solution 2:
Blower Wheel
The blower wheel works with the drive motor to draw air into the dryer drum. Clumps of lint, socks, and small articles of clothing can escape the lint filter and get caught in the blower wheel. In addition, the blower wheel sleeve can wear out, allowing the blower wheel to wobble on the motor shaft. If the blower wheel is obstructed or defective, it may take too long to dry clothes. To determine if the blower wheel is working properly, remove the dryer vent and assess the strength of the air flow. If the air flow is weak, check the blower wheel for obstructions. If no obstructions are present, try rotating the blower wheel by hand. If the blower wheel wobbles as it turns, replace it.
Solution 3:
Heating Element
The heating element warms the air before the air enters the dryer drum. If the heating element is burned out, or if any other part of the assembly is defective, the dryer may not heat. To determine if the heating element is at fault, use a multimeter to test it for continuity. If the heating element does not have continuity, replace it.
Solution 4:
Lint Filter
The lint filter might be clogged. Dryer sheets and fabric softener can leave a residue on the lint filter, reducing the air flow. If the lint filter is clogged, clean it.
Solution 5:
High Limit Thermostat
The high-limit thermostat monitors the dryer temperature and shuts off the burner if the dryer overheats. If the high-limit thermostat is malfunctioning, it may shut off the burner even if the dryer is not overheating. However, this is rarely the case. Before replacing the high limit thermostat check all the more commonly defective parts. If you have determined that all of the other components are working properly, test the thermostat by using a multimeter to test it for continuity. If the thermostat does not have continuity, replace it.
Solution 6:
Cycling Thermostat
The cycling thermostat cycles the heat on and off to regulate the air temperature. If the cycling thermostat is defective, the dryer will not heat. However, this is rarely the case. Before replacing the cycling thermostat check all the more commonly defective parts. If you have determined that all of the other components are working properly, test the thermostat by using a multimeter to test for continuity. If the thermostat does not have continuity, replace it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Check the dryer's filter(s) for lint clogging. Also check for the same on the air discharge hose located on the back of the dryer. You can also go outside to where the air discharge vent is located and see if you are getting good air discharge pressure there. If the air circulation is impeded, then drying capability is also impeded. Make sure there are no kinks or abrupt turns in the discharge hose that will allow lint buildup. Unless your dryer uses a dual heating coil setup with one coil burnt out/broken, your dryer should be working fine. Best to check for air circulation blockage first, imho.
Puan 0
Yorum Ekle
Yanıtını ekle
Adam Piazza sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 367
