Whirlpool Gold dishwasher runs in short cycle but not normal cycle
I have a Whirlpool Gold Series (model WDT920SADM0) that is about 5 years old. Within the last few weeks we noticed that the “normal” cycle would not clean dishes and detergent pods would be left practically intact in the bottom of the dishwasher.
This led me to believe it was a pump issue, so I ran a short/1-hour cycle. However, the 1-hour cycle does run as expected with water getting into the dishwasher and all detergent being fully utilized in the cleaning cycle. (Of course, the 1-hour cycle doesn’t clean to the degree of the normal (3-hour) cycle, and we’re left with the frustrating task of washing several items by hand after the 1-hour cycle is complete.)
I’ve followed the steps to do a full reset by shutting power off at the breaker, then powering back on, thinking there could be a computer issue. This has not resulted in resolution.
I’m at a loss at this point. It doesn’t seem like a pump issue, and it’s unclear if this is a computer issue. Regardless I have a semi-functional dishwasher and need some help! I’m grateful for any insight, guidance or help offered!
Update (09/08/2019)
@SaraFilthaut and @Ali, in the end we replaced the dishwasher with a different make and model. I discovered that the cost of parts was going to be at a level that made me question repairing a 5-year old dishwasher vs. replacing with new. Between computer boards and pumps, I preferred to have a highly rated and new dishwasher and stop the madness.
Bu iyi bir soru mu?
Owner's Manual mentions an optical sensor:
This dishwasher is equipped with an optical sensor wash that
detects water temperature, soil, and detergent amount. Wash
cycles are adjusted based on the load sensing.
Also check the documentation on cleaning filters (might explain the 1 hour not cleaning properly).
https://www.searspartsdirect.com/manual/...
Just out of curiosity though, is 3 hour cycles normal for newer dish washing machines (I guess also depending on brand)? Seems quite excessive, imho, and the guide mentions the 1 hour cycle but not the length of the extended cycle(s).
prop man tarafından
@propman Thanks for commenting. The “normal” cycle on this Whirlpool (and I believe many dishwashers now) is about 3 hours. Apparently this is the most energy/water efficient as it allows the sensors to assess the progress of the dishes as they clean. I’ve diligently cleaned our filters over the last 12 months.
One thing I’ve noticed on the normal cycle is the dishwasher takes in water for an initial rinse, then drains that water. After that it counts down until 3 hours have passed without making a sound (there are occasional “clicks” that sound like signals are being sent to switches). About 5 mins into the cycle I hear the soap door pop open, but there isn’t additional water intake for cleaning. That is why this is so interesting - the 1-hour cycle seems to function normally (as in, doesn’t “go silent” during the cycle).
I don’t see how the dishwasher can work normally for one type of cycle, but not for another. I’m going to test the other cycles (heavy, pots/pans) next.
Derek Sisterhen tarafından
@dpodepot Thanks for the update on the 3 hour info. If there is more than one sensor in the unit, then maybe one is not used during the short cycle because it is not needed for a more detailed washing session. If however there is one used during an extended washing cycle session and it is malfunctioning, it could be it's not transmitting the correct signal to the water inlet circuitry. Certainly no expert here and wish I could offer more but hopefully someone more knowledgable than myself will be able to offer further suggestions or solution. Thanks again for the update. Appreciated. :-)
prop man tarafından
Hi @dpodepot ,
Check behind the kickplate (toeplate?) as sometimes the "tech sheet"(aka service manual) is sometimes located there.
If it is then it should help with how to run the diagnostics to check the machine.
Just a thought.
jayeff tarafından
@jayeff Thanks for that suggestion. I didn’t find a manual behind the kick plate but will look it up online. I’m going to see about running the diagnostic because I’m noticing that the dishwasher functions mostly in other cycles (short/1-hour, and heavy), but not entirely. Perhaps running a diagnostic will yield an error code that can clarify this issue.
7 tane daha yorum göster
