Model 29875GE2-B doesn't answer
Machine does not answer. Have checked all connections. Disconnected power, waited, and reconnected. Re -programed. No joy
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
No expert on these units so the following may or may not be applicable as a solution to your problem. Does your unit have a backup battery (saves settings in case power goes out). If it does, it may need replacing. The user's manual states the the "answerer must be switched on". If the battery does need replacing it could also mean that the settings for the answerer have been toggled off. Just a thought.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 194
