The screen no longer rotates
I have an LG tablet model VK 815 (Verizon) running Android 6.0 (no longer updates).
The screen suddenly stopped auto rotating. I tried everything, including an entire Factory Reset but nothing seems to work. Help ?
Bu iyi bir soru mu?
Puan
0
If applicable to your unit, after the factory reset did you check your settings to make sure rotation was enabled? If it is enabled and no other method produces results then more than likely you have hardware component failure. Might want to try checking the Play Store with respect to rotation apps that may shed some further light on the situation.
prop man tarafından
